Area 51% wrote:From here, it doesn't look like anything other than the spar has been compromised. New spar....done deal. That is, unless the factory has another option.
If you do query the factory tech, do it soon as Kerry's last day is Friday I believe.
I just completed these units two days ago myself. The problem I ran into was the little radius blocks. They show a 1/8in radius on the print, but the radius on the root rib attach angle is 1/4in. The rivet and bolt holes come up through the middle of the radius. A thicker block was needed. .
Bryan Cotton wrote:Call Kerry. But also can you make a new W13-02R out of raw angle stock?
Area 51% wrote:Interesting that you have to drill the holes in the 02 attach angles. I picked up my wing kit in May and all pilot holes (including the wing rib holes) have already been drilled.
I thought a "B" came with the machined angle component package .
Users browsing this forum: No registered users and 20 guests
