GordonTurner wrote:Probably works great in ultralights. Haven’t really studied them but I think they may tend to have more upright “jug” type tanks with vented caps…brought probably works great there.
GordonTurner wrote:... Went to KUS manufacturing (located in Florida), got their basic stainless steel marine unit. It’s a vertical shaft (I got either 8.5”inside the tank (from the top), the only moving part is the donut shaped float. Quality seems very high and it should program easily with typical resistance ohm settings. To install it required something like a 1.125” hole for the sensor, and the five bolt SAE pattern. I purchased stainless bolts that are something like 1.5” king. I ground flats in the pointy end of each bolt to grip with pliers, then ran each one through a die to fix the threads....
