Bryan Cotton wrote:Murray,
I would not shorten the cable. Right now you are the trim, and with a shorter cable you will still be the trim. It should be in trim at cruise with your feet on the floor.
The factory supplied trim tab works. I put mine on a couple of months ago. I put it on with aluminum rivets to make it easy to remove and re-bend.
You could also put a spring to pull one of the pedals towards the firewall. Or if you have those tensioning springs installed, make one shorter. I left my tensioning springs out.
jerryhain wrote:My Waiex had one of the ruddervader‘s built with a slight twist. I adjusted them at the 2/3 up from the bottom and it corrected my roll.
Users browsing this forum: Capt T and 11 guests
