T41pilot wrote:I just noticed my tank has buckled worse than it was before even with the new straps fitted quite loosely. I've had varying amounts of fuel in it all summer. It would be a nightmare to get it out now that the plane is done. It is buckling inward and pulling away from the straps so the loose straps on the bottom have no effect. My guess is the tight fit on the sides and top is still to blame. I'm using it as is for now since it doesn't leak but it definitely looks bad. 20 gallon quantity is not accurate anymore. A new type of tank should be made with slightly smaller dimensions sides and top and or a different material should be used. It would be nice if Sonex could come up with a proper solution for this.
jrs wrote:Question for the group of "B" builders. Has everyone that installed the original tanks had problems with the install. I have the modified straps but it sounds like those don't always fix the problem. Do these tanks always fail ?
