rk2436 wrote:Is your prop ground adjustable? Look for about 5200-5300 static. It’s not good for the engine to be overpitched.
WilliamBatten wrote:rk2436 wrote:Is your prop ground adjustable? Look for about 5200-5300 static. It’s not good for the engine to be overpitched.
Just curious - why do you say it is not good for the engine? What effect does it have on the engine if it is "overpitched"?
Murray Parr wrote:rk2436 wrote:Is your prop ground adjustable? Look for about 5200-5300 static. It’s not good for the engine to be overpitched.
It is the fixed pitch 64" x 81 that Sonex/Sensenich were trying out earlier. I think they now sell 60" x 82 instead. I spoke with Sensenich and they said it could be trimmed but I am not sure who I could get in Australia to do that or where to find the info to do it myself.
roberto51it wrote:WilliamBatten wrote:rk2436 wrote:Is your prop ground adjustable? Look for about 5200-5300 static. It’s not good for the engine to be overpitched.
I had a similar situation in my actual RANS S7, and was told by the ROTAX rappresentative’s mechanic that overpitching the engine, the crankshaft, being a press-assembled one (not a one-piece crankshaft) could move and get out of alignment with disastrous consequences…Just to be on the safe side, I diminished pitch as to have 5200rpm stationary as the manuals say…
Roberto from Italy
Kit #1433
sonex892. wrote:Murray Parr wrote:rk2436 wrote:Is your prop ground adjustable? Look for about 5200-5300 static. It’s not good for the engine to be overpitched.
Hi Murray.
Congratulations on the first flight.
Is the prop timber? Is it 2 blade? If it is timber there is no great skill involved in removing a bit from the diameter, just make each side symetrical measured from the centre. If your prop is glass covered I would avoid trying to reduce the pitch. With any alterations, balancing afterwards is the most crucial part.
I'm no professional prop maker, I have made 3 props over the years and my 3300 jab sonex has 570hrs on it and only flown with props I've made.
Steve
