Skippydiesel wrote:Engine Run Time 30 hrs - approximately 25 flight hours.
I have the Mk2 Rotax/Sonex rail type engine mounting system.
In the short time the system has been in use, I have noticed an increase in engine movement (resulting in strike/rub marks on left side) probably happening at shut down.
Before you ask, in an attempt to "soften" the typical Rotax shut down movement - I take great pains to reduce engine speed to low idle (1800 rpm) and then "kill" each ignition individually, pausing briefly between actions.
Back to the mounting system - specifically the isolation rubbers - I would like to explore installing slightly harder rubbers - I believe the "rubbers" are supplied by Barry and that diffrent hardness/compressions are available. Am I correct in this belief?
If you have knowledge/experience of alternative rubbers please advise.
My thanks in anticipations.
Skippydiesel wrote:[i]
Do you happen to know if there is a Barry Shock Mount hardness above 22001-13 Green/White Hard Durometer???
Murray Parr wrote:Skippydiesel wrote:[i]
The only info I've found is on aircraft spruce website. It states "The standard neoprene elastomer is resistant to oil, and other materials are available on special order."
Murray Parr wrote:There is a Data sheet on Spruce website which shows 2 harder durometer bushes. Specs are on page 6. Part numbers 22001-14 & 22001-15
Murray Parr wrote:[quote="Skippydiesel
I tried to install the washer kits on the weekend but the 1/2" ID ones don't fit, the male Barry mount it is supposed to go over is more like .570" I will probably have to ream them out some.
