Wastintime wrote:While I'm not crazy about the aerovee engine, it seems like you could build a decently equipped Waiex for at least half the price, if not slightly better, of an RV-8.
Wastintime wrote:Ideally I'd want the performance of the 120hp Jabiru engine, but the pricetag just doesn't make it worthwhile to me especially when I know I'd essentially like it to be Night IFR equipped. I'm not saying I'd ever fly it to minimums or that it'd be a fun IFR plane, however, I do fly in the SFRA and FRZ, so certain equipment is a must, plus I like flying at night. So I'd rather spend 1/3 of the Jabiru on the Aerovee.
Wastintime wrote:Now, I don't really have any intentions of doing hardcore aerobatics, but oil starvation is a real thing on a non-dry sumped motor and having flown aerobatic aircraft, I know I want to be able to be upside down and do some loops and rolls.
Wastintime wrote:Obviously it's not super fast, but with ground adjustable prop it might not be that bad on an XC flight.
Wastintime wrote:One of my big concerns is the gross weight, that it's just so light it will fly worse than a 152 on a windy day. Is that the case?
Wastintime wrote: How does it handle, how is it as far as aerobatics are concerned,
Wastintime wrote:I've worked in Porsche race shops since I was in college, I've built several race cars, kit cars, etc...
Wastintime wrote:Still, I'd love to hear some impression on how the Sonex builds actually go.
There was one accident of a Waiex that had a structural seperation of the tail. The exact cause of that breakup isn't clear
Wastintime wrote: Still, I'd love to hear some impression on how the Sonex builds actually go.
BK9977 wrote:One other thing I have heard multiple Waiex pilots complain about is that while in the air they handle similar to the Sonex, on the ground they are rather limited in crosswinds because lack of rudder authority. I have heard Waiex pilots say anything over 7mph starts getting a little wild. I know some have told me they have to line up on one edge of the runway because they will be pushed over to the other side before yaw becomes effective. Some have gone in the grass off the side of the runway because of this.
BK9977 wrote:One other thing on the acro, with the aerocarb/aeroinjector, it does not regulate flow. So in a routine your mixture will be all over the place, way lean over the top of a loop, to way rich coming out of the bottom....
Wastintime wrote:Do I want to build a Waiex?
Wastintime wrote:... Ideally I'd want the performance of the 120hp Jabiru engine, but the pricetag just doesn't make it worthwhile to me ...
BK9977 wrote:Actually the NTSB found that the Waiex was designed with improper engineering for y/v tail aircraft. Sonex immediately issued a fix before there was any preliminary cause.
As for acro, I am still not convinced the Y-tail is up to par with a conventional tail. I have time in both and while they do behave similarly they are not the same.
Users browsing this forum: Google [Bot] and 93 guests
