by Kai » Sat Jun 09, 2018 2:08 am
I have been using a Sensenich wood/glass prop on my Jab powered Sonex in combination with the standard massive Sonex supplied spinner since it took to the air in 2005. The only thing that centers the prop on the engine prop flange, are the Jab supplied prop drive lugs, originally with a very snug fit in the prop boss. Every time the prop goes on after the annual, maintenance- whatever, the holes in the prop boss for the drive lugs are getting just a small fraction larger. Finally, after 13 seasons in the air, the hole diameter has increased to such an extent that the prop has become almost impossible to center properly. The result is a peculiar resonance in the airframe, starting around 2800rpm.
Has anybody else experienced this? Is there a cure for it? Comments?
Kai
Sonex #0525 DS-TD
Sonex A #0525- SG, DS.
