Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby Bryan Cotton » Fri Mar 10, 2023 1:43 am
In other threads there was discussion of top cowl pin retention for the vertically split configuration. This is what I have:
It works and is very positive. But, you can inadvertently close the fuel door without capturing the pin and then it can vibrate forward into the prop.
Postby GordonTurner » Fri Mar 10, 2023 11:33 am
Paint it white with red stripes. That always works.
Postby GraemeSmith » Fri Mar 10, 2023 3:20 pm
Why not adjust the length so it can't move forward and wreck the prop? Even if incorrectly fitted.
My builder made the end at the fuel tank a folded "rectangle" - once fitted you rotate it 180 degrees so it is down beside the fuel cap. It's not going anywhere there.
Graeme JW Smith
GraemeSmith
Postby sonex892. » Sun Mar 12, 2023 12:15 am
Bryan Cotton wrote:In other threads there was discussion of top cowl pin retention for the vertically split configuration. This is what I have:
See if you can use the hole provided in the filler box like this. You may need to cut a hinge loop away. It cant travel forward.
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby Bryan Cotton » Sun Mar 12, 2023 12:20 am
Good ideas guys. I think we won't make the mistake again - but on the next Waiex we build I think we will do a more mistake proof solution like some of the ones suggested.
Postby Bryan Cotton » Tue Mar 14, 2023 9:33 pm
Was going to fly to Tennessee today to visit my parents. Mom ended up with a bad cold and they waved us off yesterday. Today we flew to the halfway point (KBMG) and back. 4.5 hours of cross country practice for Adam.
Postby Bryan Cotton » Sun Mar 26, 2023 11:11 am
I got an email from Lonnie Prince that our prop repairs are done and he is doing the refinishing now. I'll be glad to have our prop back. We are pulling a little over 2900 in climb with the Sensenich and that is 70 HP according to the Aeroconversions graph. We typically climb at 3150 with the Prince and that is about 6 more HP.
First flat tyre today. I think we need to do a better preflight on them. The wheelpants hide the tire but when we pulled off the wheel it was worn through the cords.
I really need to figure out the alignment. 71.5 hours on this tyre.
Postby GraemeSmith » Sun Mar 26, 2023 4:18 pm
Switch to 5.00 x 5 tires. Those go-kart tires are junk
Graeme JW Smith
GraemeSmith
Postby daleandee » Sun Mar 26, 2023 7:01 pm
GraemeSmith wrote:Switch to 5.00 x 5 tires. Those go-kart tires are junk
I'm considering putting the larger tires on mine to better handle the grass fields I like to visit .
As far as the factory 11X4-5 tires are concerned, I don't see them as junk as I put 200 hours on my first set and there was more life left in them. I replaced them about 100 hours ago with the same tires and these still look like new.
I fly off of pavement and my plane is a Corvair powered taildragger so it's likely a bit heavier than standard. But I will say the the wheel alignment on mine is absolutely spot on. I had a great building mentor that I worked with when building this plane.
In another thread discussing tire life Art reported 457 hours on a set of the "junk" tires. I began that thread in hopes of discovering why some pilots get long life from tires and others can't ... but it didn't get much participation.
viewtopic.php?f=38&t=7084&p=53508&hilit=tire+wear#p53508
Postby Sonex1517 » Sun Mar 26, 2023 10:50 pm
Bryan
I upsized my tires to the 5.00 x 5 and have no regrets. Flying without the wheel pants for the past two years. Do not miss them a bit.
Return to Photo Album
Users browsing this forum: Google [Bot] and 3 guests
