Where does the Roll Servo go?
Postby dboeshaar » Sat Mar 11, 2023 1:14 pm
Greetings!
I'm building a Sonex Model B. Expected shipping for the airframe is 3/17/2023
I'm building the wings first
I want to wait as long as possible for the avionics. Get the best upgrades.
I'm going with GRT panel
I want to have autopilot
I know the pitch servo is in the fuselage
BUT
Where is the roll servo? Since I'm building the wings now, do I need to buy the servos now?
Where do folks put the roll servo?
advTHANKSance
Dkb
David Boeshaar
KWHP
TDAIRCRAFT.COM
My Greatest Fear: What if the Hokey Pokey really is what it's all about?
dboeshaar
Re: Where does the Roll Servo go?
Postby DCASonex » Mon Mar 13, 2023 9:42 am
Not sure how applicable my mounting in a center stick "A" series is, but you can find it here:
https://sonexfoundation.com/the-amsler-files
Auto pilot is the first category listed.
Postby GordonTurner » Mon Mar 13, 2023 11:31 am
I did put mine in the wing. Made for a nice uncluttered installation. I put the pitch servo under the seat. In the a the seat comes out, since it doesn’t in the B make sure you have maintenance/replacement (hope not…) access to anything you out there.
Here’s the link to my roll servo:
https://imgur.com/gallery/0hD4z
Best of luck, let us know what you decide.
Gordon
Postby Spaceman » Mon Mar 13, 2023 5:18 pm
I put mine under the seat like this:
http://paegelow.blogspot.com/2020/02/au ... 7.html?m=1
Chris Paegelow
Spaceman
Postby dboeshaar » Mon Mar 13, 2023 10:59 pm
Thank you all!
This is a great help. I'll keep you in the loop as we progress.
My Airframe delivery date is THURSDAY!
Gung Ho!
(Gung = To Work, Ho = in harmony)
Dkb
David Boeshaar
KWHP
TDAIRCRAFT.COM
dboeshaar
Postby sonex892. » Tue Mar 14, 2023 12:07 am
Spaceman wrote:I put mine under the seat like this:
There is some really good info on Chris's blog. This is very similar to the mgl servo installation in my A model.
One thing that may not be apparent with this roll servo location, is the roll movement is 3 dimensional and the roll servo arm position alters with forward and aft stick movement. The servo end stop position for hard left aileron with stick forward is not the same servo end stop position as hard left aileron with stick aft. The same goes for the right aileron. I too had to fabricate a longer servo arm for the roll servo to reduce the total angle of throw to eliminate the risk of going over center and locking the controls.
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby DCASonex » Tue Mar 14, 2023 9:38 am
I addressed this by mounting my roll servo off the base frame of my center stick so it moves with the stick. Where I located it, Its mass also helps offset some of the added pull from the bungee cord as it is stretched as stick is pushed forward.
Postby daleandee » Tue Mar 14, 2023 11:02 am
My roll control is located under the passenger seat. I also had to extend the arm on the gold standard servo and set it up carefully to prevent not only an over center situation but also to insure that the stops on the stick were engaged slightly before the stops on the servo.
David ... your method of mounting sounds very intriguing. Any photos you'd like to share?
Dale
3.0 Corvair/Taildragger
Postby DCASonex » Wed Mar 15, 2023 9:20 am
Dale,
Photos and drawings can be found on the Sonex Foundation website:
Under heading of autopilot, which is the first in the list of my customizations.
Postby daleandee » Wed Mar 15, 2023 1:10 pm
DCASonex wrote:Dale,
Excellent approach!
Thank you sir ...
Dale
Edit: in looking closely at those photos I noticed the location where the roll control is attached to the stick. During my install I attempted to use that same location but found the push rod would slightly contact the seat pan so I used an extended bolt from the aileron connecting rod location.
Return to Sonex-B / Waiex-B
