Protectant for polished aluminum
Postby gknowles » Sun Mar 12, 2023 12:19 pm
Hi all,
Checking again after a decade or so to see if anyone has had any success using any sort of protectant after polishing, ie to prolong the time between polishing. No doubt there are lots of products that make great claims, like Sharkhide, but does anything really work?
Thx
Garth
gknowles
Re: Protectant for polished aluminum
Postby GraemeSmith » Sun Mar 12, 2023 4:23 pm
Elbow Grease....
Graeme JW Smith
GraemeSmith
Postby Bryan Cotton » Sun Mar 12, 2023 5:34 pm
I've been using oil on the belly. I'll let you know how it works out after some more time.
Postby DCASonex » Mon Mar 13, 2023 9:36 am
If your plane is in a closed hangar, cover it with a soft cloth. Dust holds moisture that results in corrosion.
DCASonex
Postby Scott Todd » Thu Mar 16, 2023 10:23 am
Bryan Cotton wrote:I've been using oil on the belly. I'll let you know how it works out after some more time.
Me too! But in my case, its protecting the paint.
Some of my airport buddies are REALLY broke up about it and say how bad it is. I just smile and say its a VW thing and then remind them to go look under a radial powered airplane :)
Scott Todd
Postby Bryan Cotton » Thu Mar 16, 2023 11:34 am
For as much mess as there is, I only have to add a half quart every 10 hours. As long as it's dripping I know there is still oil in there.
Postby Scott Todd » Thu Mar 16, 2023 5:15 pm
I think I'm a bit less than that Bryan. The belly protectant bugged me a little early on but I'm over it :) Just Fly!
I hear the polished guys say that the key is to do it regular. If you let it go, it takes a lot more work. Outside, every year. Inside, every other year.
Scott Todd
Return to Finish methods
