Aux Fuel Tank Plans
Re: Aux Fuel Tank Plans
Postby 142YX » Sat Feb 25, 2023 9:35 pm
Resurrecting an old thread:
I am in search of the behind-the-seat aluminum fuel tank plans that used to be somewhat popular. The were an ~8 gal wedge shape that fit between the seat and the baggage compartment. Have found many links in various places, but they are all dead-ends to websites that are no longer active. Does anyone have a copy of those plans that they would be willing to send me?
Thanks much in advance.
450 hours and counting..
142YX
Postby peter anson » Sun Feb 26, 2023 12:26 am
Here is a link to plans on the Sonex Australia site. Pretty sure this is the design by Steve Woodham and used successfully by him.
https://www.sonexaus.org.au/wp-content/uploads/2018/07/fuel-tank-pdf-4.pdf
peter anson
Postby 142YX » Sun Feb 26, 2023 1:26 am
peter anson wrote:Here is a link to plans on the Sonex Australia site.
Thank you! I think I remember seeing these years back. I also think I saw a welded aluminum tank design somewhere - or maybe I am making that up. Does anyone remember a welded tank like that?
EDIT - Thinking about this a little harder.. I believe this design will work ether being riveted and sealed together, or welded. This is probably what I am remembering. This article helped jog my memory:
https://www.eaa.org/eaa/aircraft-buildi ... -fuel-tank
142YX
Postby sonex892. » Sun Feb 26, 2023 4:25 pm
142YX wrote:Thank you! I think I remember seeing these years back. I also think I saw a welded aluminum tank design somewhere - or maybe I am making that up. Does anyone remember a welded tank like that?
These tank plans are my design. It holds 32 litres, weighs 6 lbs empty and can be removed or installed in 10 minutes. I've been using my original tank for 12 years now. Thankyou Peter for finding the link to the plans.
I used the Vans fuel tank sealant and rivets. There is no reason it couldn't be welded. It is a tight fit in the aircraft so would need to keep clearances in mind if building.
Steve
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby karmarepair » Sun Feb 26, 2023 5:29 pm
Any pictures of it installed? I'm not quite getting how it installs to the structure aft of the seat back.
karmarepair
Postby daleandee » Sun Feb 26, 2023 6:54 pm
I really like Steve's design and have had that page book marked for a long time for when I want to add an aux fuel tank.
But don't forget this approach also:
https://rvpilotlife.wordpress.com/2016/ ... fuel-tank/
Not sure if the white poly tanks are still available. Here are black poly tanks:
https://www.speedwaymotors.com/Black-Po ... ,5404.html
Postby sonex892. » Sun Feb 26, 2023 7:46 pm
karmarepair wrote:Any pictures of it installed? I'm not quite getting how it installs to the structure aft of the seat back.
I have a new computer and at the moment cant access my external HD with the photos.
Its held in place with only a piano hinge each side. There is an angle stiffener behind the hinge on the vertical member and a couple of angles at the bottom attaching the vertical members to the horizontal. There are also internal stiffener angles inside the ends of the tank and 2 baffles.
There are a a couple of photos of the tank installed here.
https://www.sonexaus.org.au/galleries/m ... sonex-892/
Steve
Steve
Sonex kit 2010
sonex892.
