by dbdevkc » Wed Feb 01, 2023 4:01 am
I used some tubing I got from Aircraft Spruce. It is very thin walled, so it’s actually looser in the tooling holes than I expected. What I did was put a zip tie around it on the outboard side of rib #17 so the tube itself can’t slide inboard, and a zip tie on it at the inboard side of the #1 rib, so the tube can’t slide outboard. Also, doing it that way I could always remove both zip ties and remove the tube in the future if I ever need to - not that there ever should be reason to do so I can imagine.
I did not use bushings/grommets.
[color=#800000]Kevin Conklin
Building Waiex #169
