by Wood » Tue May 02, 2023 8:31 am
I ended up doing a complete valve job after lost compression on number 2 and 4. It was a result of the valve guides coming unseated and ended up throwing a couple of rods.
After talking to Nick at Arion Aircraft I decided to change all my valves to the double spring instead of the original single spring.
Try to find an aircraft engine shop here was impossible as they would not touch it due to liability issues. So I ended up finding competition engines ( great guys and awesome work). The support between them and Nick and the collaboration between both Competition engines and Arion aircraft on aparts and questions was great.
It took about 3 months to complete the job which was understandable and cost me roughly $3500 CDN.
Just be an aware which I had issues and no fault of Nicks whatsoever ever it was an issues with the distributor of the oversized valve seats that needed to be replaced. It seemed that when they set my oversized seats they did not send a pinch number with it and that needed to be found out before they could be fitted.
I will say that the service between Nick at Airion and Competition Engines was impressive.
Good luck with that repair
Lyncrest Airport - CJL5
Winnipeg, Manitoba
Sonex Legacy #0327
Jabiru 2200
Serial # 22A 1130
AeroConversions
