pfhoeycfi wrote:I have the B with the aeroconversion brakes. They work well at runup and the turn radius is fine. If I see air in the lines I pop the cap on the res and pump the handle which actually pulls the air back to the res and out the fill. The tubing tees at the firewall. That's "plastidip" on the handle. Years back I was persuaded to install tow brakes on my Sonerai 2 (similar size, speeds, weight etc) after having flown it for few years with just the single handbrake....a few hours later I pulled them back out...
Zack wrote:I have a center stick Model B, what is the preferred option to allow actuation of the brakes from both seats? I've seen the center mount master cylinder, which would be difficult to use with a center stick.
Users browsing this forum: No registered users and 38 guests
