MGL MX1 recording file
Postby pfhoeycfi » Mon Jan 02, 2023 1:28 pm
Does anyone know the exact procedure for creating the MGL recording file? I have the MX1 but I'm sure they are all similar. I've tried creating the file before the flight and after the flight...all ng. Do I make the file just once, or for every flight? Do I make the recording file before or after the flight? The instructions leave alot to the imagination. I've tried it a bunch of different ways and I end up with no file on the sd card or an empty file on the sd card. Recording is enabled.
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Re: MGL MX1 recording file
Postby XenosN42 » Mon Jan 02, 2023 3:23 pm
You'll only need to create the 10MB recording file once. If you do it again it will create a new file thereby wiping out any data recorded from previous flights.
Your issue is that the recording is not starting. On some MGL EFIS devices they give you the option to start recording manually or to start on 'automatic flight detect'. I've always liked to start the recording manually, BUT unfortunately MGL has removed that option for the MX1.
Go to this web address https://www.michiganavionics.com/product/iefis-mx1/#
Click on the < Download > button next to "iEFIS Menus"
On page 11 of that PDF you will see the menu needed to setup 'Automatic flight detect'. For a Sonex I'd suggest an RPM of around 900 and ASI of 30MPH.
Some more information from the chief software engineer at MGL: https://www.mglavionics.co.za/phpBB3/viewtopic.php?f=3&t=705 The important information is in the third post written by 'rainier', the aforementioned software engineer.
Good luck.
-- Michael
OneX N169XE
XenosN42
Postby pfhoeycfi » Mon Jan 02, 2023 3:59 pm
Great, thank you...
peter
Peter Hoey
pfhoeycfi
