"Status Models and Serial Numbers. Date of Issue . Reference Number
REQUIRED All Legacy Sonex, Waiex and Xenos Airframes 05.31.22 SNX-SB-011
Unsafe Center-mounted Throttle Installations:
A common builder modification is to move the throttle (and mixture control) to the center of the cockpit, but leave the flap lever and brake lever on the left wall of the cockpit. This creates a dangerous need to change hands on the joystick during critical phases of flight (climb-out, maneuvering, landing, go-around). Moving ONLY the throttle (and mixture control) to the center of the cockpit is NOT a Sonex-approved control configuration.
The cockpit MUST be configured so one of the pilot’s hands can remain on the stick at all times while the other hand remains free to operate the other controls (throttle, mixture, flaps, brakes, trim).
Corrective Actions:
If a center-mounted throttle is necessary, the flap and brake handles (as well as mixture control and trim control) MUST be moved to the centerline of the aircraft. Sonex specifically designed the Sport Trainer (ST) modification to accommodate center-mounted controls.
- SNX-C08_OptionalCenterControls_A.pdf
- SNX-C09_OptionalCenterDetails_A.pdf
If a center-mounted throttle is not necessary, the throttle (as well as mixture control and trim control) MUST be moved to the left side of the cockpit, near the flap and brake handles."
GordonTurner wrote:Electric flaps are pretty easy to implement. Might be worth considering.
Gordon
