by Rynoth » Sun Jan 19, 2014 9:17 am
I'm also going to aerobatic ailerons, though I haven't built them yet. In looking forward in the plans, there appears to be no hardware or parts difference, other than the fact that you need 2 control surface skins (per wing) of sufficient length to cut down to proper size for flaps/ailerons. They use the same number of ribs in the kit (I think 1 or 2 ribs from the old flap go into the larger aileron). Basically you end up taking about 16" off the flap and adding 16" to the aileron, making them very similar in length.
The aileron bellcrank and pushrod locations stay the same (as do the flap pushrods.) You do end up having to make a small cutout in the aileron for the pushrod, since it comes through 16" from the inboard end of aileron rather than the inboard rib of the aileron.
Honestly, unless I'm missing something, I think that it wouldn't be hard to retrofit aerobatic ailerons/flaps on an existing sonex, as long as the piano hinges lined up correctly.
Edit: Since the flaps pivot from the bottom and the ailerons from the top, I think the only difference in the way the wings are built is where the piano hinges go.
Rynoth on Sun Jan 19, 2014 12:10 pm, edited 2 times in total.
