by dbdevkc » Sun Nov 27, 2022 11:01 pm
I am questioning the way I am figuring on the root rib installation.
I have the wing skins fitted. I have the aft skins up-drilled, but the leading edge skin is not up-drilled/dimpled. I also do not have the aileron or flap hinges attached.
I figure I need to remove one of the aft skins so that I can drill through the aft root rib attach angles, up-drill, then rivet. While I have the skin off I can also drill the aileron bell crank support bracket in the other aft skin. Then reinstall that skin and remove the opposite side to drill the aileron bell crank support bracket in that first skin. Install the skin, then I can drill the holes through the skins into the root rib flange.
For the front root rib, I figure I have to do the same (remove the skin, drill and rivet the forward root rib to the attach angle, install the forward skin and drill the holes from skin to root rib flanges). One question is, should I up-drill the forward skin now, so that when I pull it off I can dimple everything, or should I just wait until I get the root rib installed since I will need to pull the skin again to dimple that anyway?
I have probably done things out of order a bit, but it is the only way that makes sense to me at this point.
[color=#800000]Kevin Conklin
Building Waiex #169
