"Sight" Fuel Gauges
Re: "Sight" Fuel Gauges
Postby Area 51% » Tue Nov 22, 2022 12:43 pm
Kai wrote:Yup- so did I.
However, 3 years of operation with this setup has left me with the distinct feeling that this is a slight climb mode (positive aoa) for the airfoil, causing a higher fuel level in the sight gauge than strictly available. As yet, I have not decided if this is an issue that should be dealt with.
Simply take your digital level up with you and check the angle when you're in stable flight. Adjust the plane to that angle on the ground and re-calibrate the tube.
Area 51%
Users browsing this forum: kmacht and 53 guests
