dbdevkc wrote:I understand that some of the options for wingtip lighting and landing lights are no longer available. I'd be interested in learning what are the go to options available now. I'd like to have the ability to fly at night if necessary - I know that means pods on the wingtips to mount the lights on. Also would be interesting in knowing if the wiring for the tip lights should be in front or behind the spar, shielded wire, ground at the tip, vs no ground at the tip, etc. I assume tefzel wire, but conductors, shielding, etc I would thing would depend on the light requirements. Run the wire though the rib alignment holes with snap in grommets? Sorry, so many questions. But now I am in full speed ahead mode and want to get my wings riveted up and out of the way so I can move on.
dbdevkc wrote:Do you remember where you found the mount/base? I found the 3D printer files, but would like to compare that to something that is commercially available. I assume we would use the 12v not the 24v. And Whelen calls for 18/4 - I'd probably run shielded - just because... + 1 for ground?
dbdevkc wrote:Bryan - That was helpful, thanks. The first picture was a bit confusing though. I looks like you have two tooling holes on top of each other in the back of the front ribs and you have wire running through both. Also what drives the decision on fore to aft position of the tip lights?
Users browsing this forum: autopro and 85 guests
