Sonerai13 wrote:This will vary by FAA office and often individual inspector. Neither the ELT or the transponder are "airworthiness" items. They are operational items that shouldn't have any effect on the issuance of the airworthiness certificate. The regulations specifically state that an ELT is not required for "flight testing", so by regulation it is not required until after the Phase 1 flight test is completed. However, most FAA inspectors seem to want to see it installed. Go figure. Transponder should be tested, but not necessarily before the airworthiness certificate is issued. It should not be operated until it's tested however.
I have never heard of an inspector asking to see test documentation for an ELT of any variety. That's a new one on me! There is no requirement anywhere in the FAA orders for such documentation, so the DAR is either just being extra cautious, or has been given the "word" from his supervising office. It's too bad that there is so much variation from office to office, and inspector to inspector, when we are all supposed to be singing from the same hymnal.
Bryan Cotton wrote:I had done the ELT test per the manual and wrote it in the logbook. Also IIRC he wanted the battery date in the aircraft log.
Before my inspection I confessed to the DAR that my transponder wasn't inspected yet. He told me that was an operational issue, not an airworthiness issue. I am out of the Chicagoland Mode C veil so I flew for a while, but was able to get a tech to come to our airport and certify the transponder. That would be a great option for you, even if you had to pay a little more. The test sets are pretty portable.
Bryan Cotton wrote:My DAR gave me a template and here it is with my info. I copied this into the logbook, signed it and used my pilot number too. Print out the equipment list and tape it on the back cover or somewhere. If you can work with your DAR ahead of time it is really helpful.
Users browsing this forum: Google [Bot] and 15 guests
