Well, the first thing to say is that the Sonex is already a very good design as far as crashworthiness. The plane has been tested in a few severe crashes and has held together very well.
Of course there are always ways to make improvements in any parameter, but there will be tradeoffs. For example, it's always better to avoid a crash than to survive one, and if adding 10 lbs of weight to enhance crashworthiness means taking off with 20 minutes less fuel then maybe it's safer to have the gas. Optimizing one characteristic can adversely affect others. With that said, here are some thoughts:
Minimizing vertical accelerations on occupants: Having empty space under the seat does no good if the seat pan merely collapses onto the floor. To be useful, the space needs to allow for controlled absorption of the acceleration forces. This might be done with a seat pan that "breaks away" at, say, 15Gs and then crushes metal honeycomb or foam for a few inches. These things are hard to design--much depends on occupant weight, and a seat pan that breaks away under normal use (e.g. when point-loading the seat underfoot when getting in and out of the plane) would be bad. I think a very practical way to reduce spinal loadings on occupants would be to build the airplane with the lowered seat and thereby make room for use of thicker impact-absorbent visco-elastic foam seat cushions. Unlike "regular" foam cushions these respond differentially to "fast" vs "slow" pressure (more resistance to "fast" pressure), they resist "bottoming out" abruptly, and they turn an appreciable amount of the impact energy into heat. They work very well at protecting objects, including people, from acceleration forces. A thick seat cushion of the right mix of viscoelastic foams would be an important first step in reducing the types of injuries you mention. References:
- EAR Confor Foam for seating:
http://www.earsc.com/HOME/engineering/TechnicalWhitePapers/EngineersNotebookConfor/index.asp?SID=63 - Aircraft seating and Confor foam
http://www.trelleborg.com/en/Applied-Technology/Products-and-Solutions/Energy-Control-Products/CONFOR-Cushioning-and-Impact-Absorbing-Safety-Foam/Glider-Sailplane-and-Light-Aircraft-Seat-Foam/Of course, the space under the seat pan is still important, and it would be beneficial to put something between the floor and the seat pan. Suggestons might include metallic or Nomex honeycomb material or polystyrene. The choice would require more research, and it would definitely be important to pick something that is unlikely to burn/catch fire.
Reducing horizontal acceleration on occupants: A well-adjusted lap/shoulder harness system helps tremendously (in helping to avoid contact with the aircraft structure). Also, I'm sure the long nylon shoulder harnesses provide a bit of "give" that is useful in reducing peak loads. The sloped Sonex firewall helps the plane avoid "digging in" if it impacts soil, which can be a very large factor in reducing acceleration. I suppose adding a small section with a slightly more gentle angle at the bottom of the firewall might go a bit further in this direction, but it would reduce access to important engine/exhaust components.
Other: I've thought about a lightweight foam head restraint attached to the rear canopy crossmember. This would reduce cervical loads and cranial exposure to the crossmember when the heads of occupants move violently rearward (they do this even in "regular" forward crashes).
Air bags: I know that shoulder-harness airbags are available for GA aircraft. I think we are in the "very low bang for the buck/pound" region with these in a Sonex if you've got your harness on correctly. Rollover protection is very good in the Sonex, but, like any canopy-equipped aircraft you'll probably be stuck in the plane until help arrives if it is flipped over.
Anyway, there are some ideas. Again, the plane is very strong and its slow stall speed can be a tremendous aid in reducing the energy of a crash. It makes sense to think of prudent steps to enhance crashworthiness, but even more sense to avoid crashes in the first place.
Mark W.
