Jerry09w wrote:The Aerovee has 2 pressure releif valves, one front and oe rear. You may want to make sure the long spring did not get put in the back, that would do away with the bypass for the top mount oil cooler if it gets plugged or very cold which could cause low oil pressure even it the pump is working OK. If they had been reversed that would also explain the short spring in the front relief valva. Check page 13 of the aerovee manual.
Jerry
Users browsing this forum: No registered users and 64 guests
