Dipstick interpretation
Re: Dipstick interpretation
Postby Bryan Cotton » Sun Aug 07, 2022 10:33 pm
So, using Michael's technique I'm either just at full or a little below. I'm going to fly another half hour when the weather is good.
Postby Bryan Cotton » Tue Aug 09, 2022 11:18 am
Bryan Cotton wrote:So, using Michael's technique I'm either just at full or a little below. I'm going to fly another half hour when the weather is good.
Half an hour flight - much less oil on the belly. Seems like progress. I took the dipstick out of the hot engine to let the oil drain down and I'll check it tonight.
Postby Bryan Cotton » Wed Aug 10, 2022 11:42 am
Oil was a little below full. Probably matched the small oil spot on the floor. I'm getting there.
Postby Bryan Cotton » Fri Sep 02, 2022 10:37 pm
I'm not keen on the stock Aerovee dipstick. So I bought a stock VW dipstick:
https://www.ebay.com/itm/172982182261
It works great! But only when the cowl is off. So I got to thinking if I could make an access hatch it would be awesome. I decided to modify the dipstick so I could minimize access requirements. First I made a shim to jam in the handle.
Then I welded it:
Cut the handle off:
Finally I welded an AN3 bolt to it. I ground the cad plate off, of course.
Next up: cowl access.
Postby Bryan Cotton » Mon Sep 05, 2022 10:30 pm
So I put my cowl on the left side. I took a hole punch to a piece of blue tape, and put that over my dipstick sticky side up. Slid the dipstick out of the tube until it hit the cowl, then slid the tape up and stuck it on the inside of the cowl. Hole location defined!
The hole size is big enough to get the dipstick out. There is the stop that keeps the dipstick from going too far into the tube and that is the part that needs to clear.
I used a piece of baffle seal and just riveted it on one side. I'm thinking the air pressure should push it against the cowl. Or, we will get more airflow into the cowl.
Next up: dipstick extender.
Postby Bryan Cotton » Wed Sep 07, 2022 12:17 am
Here is my threaded aluminum dipstick extension:
Postby BRS » Wed Sep 07, 2022 12:24 am
Dress it up a bit by making a plug for the cowl-hole and fix the stick to that plug. Cut it short leaving just enough for a handle.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Postby Bryan Cotton » Wed Sep 07, 2022 7:47 am
BRS wrote:Dress it up a bit by making a plug for the cowl-hole and fix the stick to that plug. Cut it short leaving just enough for a handle.
I had considered that, but the engine moves and the cowl doesn't. The extension only goes on to check the oil.
Postby Area 51% » Wed Sep 07, 2022 1:10 pm
I also went with the stock VW dipstick for ease of reading. To get the stick in and out, I drilled a hole similar to Bryan's, but added a slot to it long and wide enough to allow passage of the completely stock stick.
Didn't think to add the flap to keep the air in.............Next time.
Postby Bryan Cotton » Wed Sep 07, 2022 7:10 pm
Area 51% wrote:I also went with the stock VW dipstick for ease of reading. To get the stick in and out, I drilled a hole similar to Bryan's, but added a slot to it long and wide enough to allow passage of the completely stock stick.
I had considered that as well - and went with what I presented.
So when is next time scheduled for?
