by 13brv3 » Thu Aug 11, 2022 12:51 pm
Greetings,
Has anyone else suspected interference between the wheel pants and the stock pitot static tube location? My wheel pants are 1" wider, and that's all to the outboard side, so it's a bit closer than the stock wheel pants would be. The tube appears completely stock, and in the correct location.
There are times when the airspeed seems erratic, and it looks like it could be affected by the wheel pants. It doesn't always seem that way though. Sometimes I'll be sure it's a problem, then it will be completely smooth. I've tried to cause problems by yawing to the right, but I can't say I've ever been able to make it happen. I've thought of trying to make a new pitot static tube that is bent outboard and maybe extended farther forward to see if it makes any difference. Just curious.
Rusty
Rusty
Fixed wing, gyroplane, A&P
