by rbarber » Thu Aug 04, 2022 1:05 pm
I would not use just anything to lube the slide. Under the right conditions (like cold), it can make the problem worse. Take the Delrin wear plate out, and lightly skuff the slide surface. Then rub in some graphite powder. Rub it hard (snicker). The graphite will imbed in the Delrin, and will remain slippery even when really cold. Repeat once a year or so...
R.
