GordonTurner wrote:Have you checked throws on the ruddervators? First, I think they are more critical, but more importantly they are adjustable. If they are all meeting their target angular throws then perhaps check the dimensions of the rudder horn, particularly how far out from the hinge line are the cable connections. If the Tailwheel or nosewheel is installed and connected that may be limiting the throw as well.
Gordon
Rynoth wrote:You need to determine what is causing the early stop and solve it. If I recall, I had to bend (concave) a couple of the washers that hold the ruddervator pushrods to the mixer, otherwise they were binding when pitching up and applying full rudder. You definitely want full rudder deflection to the stops at all pitch inputs.
If your rudder pedals are hitting the firewall before the rudder hits the stop, you'll need to shorten the length of cable between the pedals and the mixer. This is done by drilling different holes into the rudder pedal adjustment plates.
sjakulski wrote:So, after installing the Waiex mixer and cabling up the rudder I find there is not enough throw in the mixer to allow the rudder to hit the rudder stops. My rudder deflection is about an 1/8 inch shy of hitting the rudder stop on each side. Anyone else experience that?
sjakulski wrote:sjakulski wrote:So, after installing the Waiex mixer and cabling up the rudder I find there is not enough throw in the mixer to allow the rudder to hit the rudder stops. My rudder deflection is about an 1/8 inch shy of hitting the rudder stop on each side. Anyone else experience that?
After much study I have determined that the problem is the mixer itself. The top plate (used to attached the ruddervator rods) is striking the mixer shaft before the rudder cables can complete the throw. That top attach plate needs to have about an 1/8 inch trimmed from its width.
sjakulski wrote:sjakulski wrote:sjakulski wrote:So, after installing the Waiex mixer and cabling up the rudder I find there is not enough throw in the mixer to allow the rudder to hit the rudder stops. My rudder deflection is about an 1/8 inch shy of hitting the rudder stop on each side. Anyone else experience that?
Specifically, the Bolts and fender washers used to attach the ruddervators and idler rods interfere with each other as the rudder is deflected, preventing full throw of the rudder. While the WXB-C01 plan diagram shows the most inward bolt hole used for the ruddervator rods there is also an outer bolt hole, never referenced. Wondering if these holes have to be used instead? It would prevent the interference but is not what the plans call out to use (like the plans are not mostly mistakes anyway…). What do others recall? Using the outer hole will mess up the skin opening for the rod big time, I’m sure, if that is the solution…
Bryan Cotton wrote:Do you have pictures? If the fender washer hits the rod end, like mine did, you can cup the fender washer. Put a bolt in it, find a socket that matches the OD of the washer, and press the bolt so it pushes the assembly into the washer. Afterwards the washer is cup shaped. Gives clearance on the rod ends, but will retain the rod end if it fails.
Edit:
From this thread:
http://www.sonexbuilders.net/viewtopic.php?f=3&t=396
Page 5 this comes up. I discussed on my build thread too.
