Loose oil pressure sender
Postby Bryan Cotton » Tue Jul 26, 2022 10:02 pm
My sender backed out in flight. Lost a bit over a half quart. What a mess!
Video:
I've cleaned off the threads and redone the seal with loctite 515.
I've also drilled the corners of the hex for safety wire, and safetied it to one of the cylinder studs.
sealed and safetied sender.jpg (89.29 KiB) Viewed 1269 times
Re: Loose oil pressure sender
Postby Ed Perkins » Wed Aug 17, 2022 2:24 pm
Is this a somewhat common problem? In my last flight I noticed higher engine temps approaching 400 degrees. I next noticed low oil pressure at about 20 psi. I quickly landed and put plane away. I'm sure I have a problem because I normally see about 45 - 50 psi oil pressure. Hope to hear from others on this, especially if there are other common reasons for loosing oil pressure like I did. Thanks, Ed Perkins, Appleton, WI
Ed Perkins
Postby Derek1983 » Mon Sep 26, 2022 10:14 pm
Recently replaced my sender (same style vdo) came with a copper crush gasket. We were able to run it into the engine by hand up until the last thread. Sealed good with just with bottoming out the copper washer
Derek1983
