Here is a cut and paste from an email report:
I did a weather check:
KRFD 251720Z 2518/2618 VRB05KT P6SM FEW060 BKN250
For the non-pilots, that is a terminal forecast from Rockford airport, which is close to us. Translated, it means "it doesn't get better than this."
So, here is the video:
https://youtu.be/HqVvFJHf5q0I'll confess that I was pretty nervous during the day all the way through the taxi to the runway. Pretty much once I got the throttle in, I felt fine. I climbed at 80kts. Maybe 60kts would be a normal climb speed, but the extra speed 1) gave me margin above stall in an unfamiliar, unproven airplane and 2) gave better cooling on our brand new engine that Adam built when he was 14 (but almost 15). I was getting a little over 3100 RPM in the climb and somewhere around 700 feet per minute (fpm) climb. Pretty good.
Once I got to 3000' or so, I leveled out and leaned the mixture. I never got far from the airport. I miss the glider flying so if the engine quit, I wanted a chance to relive that joy ending with a landing back at home. I did some boring around at 3000 RPM and was getting about 100 knots (kts, or about 115 mph). I had my first issue that my exhaust gas temperature (EGTs) went high, and that was a pain. I was not really worried about high EGTs, especially because the more critical cylinder head temperatures (CHTs) were looking great - like under 300F. But when the display was alarming for EGTs, it would not let me look at the other parameters. Oil pressure was running around 70 psi and 220F - that was pretty good. I did some wide open throttle and saw about 3400 RPM and 120 kts. I did a bunch of turns, and some stalls with and without flaps. Without flaps it stalled around 50kts, as predicted. With flaps, it stalled 2 or 3 kts lower. The airplane has a nice pre-stall buffet to let you know you are running out of lift margin.
You will notice that the gopro video at the end was smeary - we had an oil leak happen suddenly. Turns out the oil pressure sender had gotten loose:
https://youtu.be/cgE3QmbsQ3sThat's an easy fix, but man what a mess. At least I know the aluminum belly skins and the titanium tail gear won't rust.
Summary - it ran and flew awesome. More to come.
