by GordonTurner » Tue Jul 19, 2022 4:25 pm
Hi Graeme
Can’t help you with the part. But day vfr nothing is required. If you don’t have a mechanical oil pressure and tach, you can pick up a mechanical oil pressure gauge/kit and do a temp install. Maybe the same auto parts store has something like a tiny tach as well. Should be all you need to comfortably get home, day vfr…
Good luck, Gordon
