Punch mark on oil pump gear
Postby pfhoeycfi » Wed Jul 06, 2022 12:27 pm
One of the gears on the aerovee turbo oil pump has a punch mark on it and I'm curious as to the significance of this. Anyone know?
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Re: Punch mark on oil pump gear
Postby Area 51% » Thu Jul 07, 2022 10:54 am
If it was manufactured in a government factory, it's likely someone's nephew needed a job.
Area 51%
Postby GraemeSmith » Thu Jul 07, 2022 12:56 pm
It's a timing mark. But I'm not sure what the timing set up might be - or if it even matters on that application. If you search the term:
spur gear oil pump timing mark
you will find discussions on the topic - when it matters and when it doesn't.
Graeme JW Smith
GraemeSmith
Users browsing this forum: autopro and 49 guests
