pilotyoung wrote:My engine is a non-turvo AeroVee. The manual for it says if there is more than a 50 rpm drop, that there is a problem with the timing. The primary ignition timing is fixed but the secondary, 12 volt, can be adjusted. The manual explains how to do that.
There is also a post on this site that explains it better and suggests doing a test flight, running for 5 minutes on primary, then secondary, and then there is a software program you can buy to analyze the CHT's. It will let you find the average of the CHT's when running on each ignition system. Then if they are near one another, it is adjusted correctly. If there is a large gap, the manual tells you which direction to turn the secondary ignition.
I don't know if that procedure applies to the turbo version. I hope this helps.
Waiex 0194 wrote:Listening to your video, at least one cylinder isn’t firing on either ignition, explaining the rpm drop.
Users browsing this forum: autopro and 48 guests
