Bryan Cotton wrote:No, yes. Also get the right charger and plug it in between flights.
Bryan Cotton wrote:You are using the aircraft battery for refueling? Why not your car battery? That should have a lot more reserve.
https://earthxbatteries.com/faqs/
I've seen an earthx battery die due to charge issues. It's not an uncommon practice to just charge it after each flight for longevity. The optimate charger has an optimize mode to balance the cells.
Skippydiesel wrote:... I have no prior experience with this new generation of battery ...
BRS wrote:Skippydiesel wrote:... I have no prior experience with this new generation of battery ...
The one thing that has helped me with the EarthX batteries (I have an ETX680C in the sonex and two in the Sportsman with an IO-360) is to charge the battery at idle before take-off. On the Sonex it takes me about 4 minutes - the oil is not even up to temp. If you start the engine on a partially charged battery (which it will easily do) the take off right away (ie. oil was already warm) you risk the chance of over taxing your alternator if you have a VW variety (especially RevMaster) or in the case of the Sportsman, It will easily exceed 60 amps charge current which is the limit of the 680 (not sure about the 900).
These batteries have a rather low internal resistance.
Skippydiesel wrote:BRS wrote:Skippydiesel wrote:... one of those clever little hand held/glove box battery packs
