13brv3 wrote:Sounds great, but I'd be afraid to ask what that cost. I ended up ordering an Ivo, and it should be here tomorrow. If it works at least as well as the Warp Drive, I'll be tempted to add the in-flight adjustable option. I'll try hard to resist though. I almost never fly cross country, so on the rare occasion that I do, I could easily adjust the prop for best cruise. The rest of the time it could stay on a good compromise setting for local flying.
Rusty
pschwenn wrote:Need advice on how to remove the 912iS water pump elbow that interferes with the engine mount (so that I can replace that elbow with one with a different curve.) The elbows on my 912iS are threaded into the water pump housing and then either soldered or Locktite'd in (can't tell visually, but can see the threading.)
What is the best way to remove the elbow? Does it depend on whether solder or Loctite was used?
I have tried, without success, penetrant; and heating the housing next to the elbow - both with very high temp soldering iron, and with soldering/braising torch. I guess that the heat expansion coefficient of the elbow is much higher than the housing, so conclude that heat would only work to "destroy" the Loctite, or flow solder.
I understand that the elbows and the threading are fine and fragile enough that no substantial force should be used.
The engine mount in question is the Sonex 912 mount for legacy (not B) Sonex models (mine happens to be Xenos #32). Only one elbow is interfering. The hose could just barely clear, but with the engine running the elbow would risk destruction.
Ideas? Advice? Pointers to prior answers or other info I have missed?
Thank you
Users browsing this forum: Google Adsense [Bot], Murray Parr and 1 guest
