by Darick » Mon Jan 06, 2014 1:32 pm
I'm strongly considering a lift reserve indicator from Value Engineering. It's basically a pressure differential gage with an appropriate face and an outside probe. It appears to be a very economical set-up, especially when compared to other similar products. Would anybody using this particular model, recommend the plastic or aluminum probe?
Thanks for your input.
Darick
Sonex #1646
TD, CS, AeroVee
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
