Intake Elbow Spacers
Postby mike.smith » Wed Mar 30, 2022 8:20 pm
When I built my AeroVee years ago there were no spacers between the intake elbows and the heads. Reading the latest assembly manual I see there are now spacers called for (ACV-M01-17). I'm curious what they are for? Anyone know?
Re: Intake Elbow Spacers
Postby n502pd » Wed Mar 30, 2022 9:29 pm
as far as I have concluded, foreasier removal of rear spark plugs, without having to remove the elbows. imho...!
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
n502pd
Postby Area 51% » Thu Mar 31, 2022 11:50 am
Adding them now will almost certainly require repositioning the holes in the rear baffle and alter the height of the carb.
Having said that, if you want a set, I have an unused pair you can have for the cost of shipping.
Area 51%
Postby mike.smith » Thu Mar 31, 2022 12:26 pm
Just curious. I was looking through the new manual to see if there were any noteable changes.
Postby Jerry09w » Thu Mar 31, 2022 9:44 pm
I believe weather you need them or not depends on the part number of the heads. The older heads did not need the spacers, I believe the newer heads do need them.
Jerry09w
Users browsing this forum: autopro and 73 guests
