racaldwell wrote:Steve,
The internal threads are regular NPT pipe threads. The fuel outlet is 3/8" NPT. Only the large external nut and threads are left hand.
Rick Caldwell
Xenos 0057
sjakulski wrote:The fuel tank bulkhead fitting (and OOPS fittings) that I have use reverse external threads I note. The plan calls for a finger screen which I obtained from spruce (their “standard” fitting). However, it seems that the threads of the finger screen and the bulkhead fitting are not the same. Anyone else run into this issue?
Also, the plan calls for an AN915-6 elbow fitting connected to the fuel tank’s bulkhead fitting, which as mentioned uses reverse threads. Cant get the AN915 to thread either. But, I have not heard of the AN915 using reverse threads, nor dies its description say it uses reverse thread?? Am I missing something? Did Others have issues here?
Steve
Users browsing this forum: Bing [Bot] and 23 guests
