Rotax 912 Build
Rotax 912 series discussion.
Rotax 912 Build
Postby aschlem77 » Tue Mar 08, 2022 10:43 pm
I'm building a Big bore Zipper engine. The parts are purchased from zipperbigbore.com, Jay and Hal have been great to work with. Im doing the 1622cc kit with the HP cam shaft and a through bolt kit for the case. This should yield 130hp. Plans are to add SDS or Edge fuel injection to complete the package. This project started with a 1000hr mid 2000's 912UL. Additionally i will add the slipper clutch to the gear box and the HD starter. The engine is down to the case. I have already disassembled, cleaned, inspected the heads and lapped the valves, time to move on the the machining of the case and heads to receive the larger cylinders.
aschlem77
Re: Rotax 912 Build
Postby Skippydiesel » Wed Mar 09, 2022 6:24 am
I am in owe of your project. Keep us posted. All the best
Skippydiesel
Re: Rotax 912 Build
Postby aschlem77 » Wed Mar 09, 2022 8:05 pm
On the mill.
aschlem77
Re: Rotax 912 Build
Postby aschlem77 » Thu Mar 10, 2022 5:15 pm
New cam is assembled and ready for the case
aschlem77
Re: Rotax 912 Build
Postby aschlem77 » Wed Mar 23, 2022 6:46 pm
Through bolt conversion complete and one cylinder fit.
aschlem77
Re: Rotax 912 Build
Postby gcm52 » Thu Mar 24, 2022 9:39 am
Very interesting! Please keep these photos coming.
George Mueller
Onex Trigear
Rotax 912 ULS
gcm52
Re: Rotax 912 Build
Postby Murray Parr » Thu Mar 24, 2022 6:43 pm
What milling machine are you using?
Murray Parr
WXB0015
Rotax 912ULS
MGL Explorer Lite
First flight May 6/23
RV9 builder (Sold)
Murray Parr
Re: Rotax 912 Build
Postby aschlem77 » Fri Mar 25, 2022 4:52 pm
Bridgeport J2
aschlem77
Re: Rotax 912 Build
Postby Matt541 » Sat Mar 26, 2022 10:45 am
Sweet! This is a direction I've considered as well. (Insert old school forum eating popcorn emoji..)
Matt541
Re: Rotax 912 Build
Postby aschlem77 » Tue Apr 19, 2022 9:58 pm
New pictures coming soon. Took a few weeks off. Here is one of me preparing to modifying a c-bore to fit the through holes I machined in the block. Had to remove .007 from the diameter of the pilot.
aschlem77
Return to Rotax
