by pfhoeycfi » Sat Mar 19, 2022 9:00 pm
My coolant pump won't prime and therefore I can't get the proper amount of coolant in the system. The piping is correct, the pump is running in the right direction and I tested the pump in the sink. I can put about 14 oz of coolant in... it it should take about 24. I was thinking of installing a tee in the suction line with a valve to try and fill it there while the pump is running rather than at the catch can. Any thoughts?
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
