by aschlem77 » Tue Mar 08, 2022 10:43 pm
I'm building a Big bore Zipper engine. The parts are purchased from zipperbigbore.com, Jay and Hal have been great to work with. Im doing the 1622cc kit with the HP cam shaft and a through bolt kit for the case. This should yield 130hp. Plans are to add SDS or Edge fuel injection to complete the package. This project started with a 1000hr mid 2000's 912UL. Additionally i will add the slipper clutch to the gear box and the HD starter. The engine is down to the case. I have already disassembled, cleaned, inspected the heads and lapped the valves, time to move on the the machining of the case and heads to receive the larger cylinders.
- Attachments
![912.jpg](./download/file.php?id=4055&sid=0eb79e35df8ea772c5662c0c70ec5ea8)
- 912.jpg (80.84 KiB) Viewed 5082 times
