Install the steel bottom plate, or optional ACV-P02-20 Oil Sump Plate, with the 6mm copper washers from the oil change kit and the 6mm nuts from the shakeproof nut kit. Do not over-tighten these nuts.
Oil Pan Cover Nuts..............10mm.................5(ft-lb)................60(in-lb)
Users browsing this forum: Bing [Bot] and 13 guests
