What wire?
What wire?
Postby Tony4aro » Thu Feb 17, 2022 10:42 am
Hi All,
OK... I understand about wire types, gauges, and their uses.... but in pictures of the back side of a panel... I see a white wire, and from the outside it looks like a twisted pair... and I'm guessing it is shielded. (also guessing it's 24 to 20 ga)
So... simple question... what kind/brand am I seeing... and does someone have a link to it in Aircraft Spruce?
Thanks.
Corvair powered Waiex (under construction)
N3848D
W0181
Tony4aro
Re: What wire?
Postby gammaxy » Thu Feb 17, 2022 10:53 am
Maybe you're seeing something like Aircraft Spruce #11-04477? It's shielded with two 24 gauge conductors. This link has a bunch of similar options: https://www.aircraftspruce.com/catalog/ ... ldwire.php
Re: What wire?
Postby lakespookie » Thu Feb 24, 2022 2:14 am
Probably several diffrent types depending on the installation, For what its worth i belive steinair is the cheapast source of wire.
Jill's Build Log
PPL-ASEL
Tail = Complete
Wings = Complete
Waiex-B 0054
Panel G3X
lakespookie
Re: What wire?
Postby GordonTurner » Thu Feb 24, 2022 11:36 am
If not cheapest, certainly 100% reliable and high quality stuff. Nice to deal with as well.
Gordon
Re: What wire?
Postby Tony4aro » Fri Feb 25, 2022 9:52 am
Thanks... I will look at Steinair for wire
N3848D
W0181
Tony4aro
Return to Panel
