Thermos Style Pressure Fuel Cap failure
Postby GraemeSmith » Thu Feb 10, 2022 7:47 pm
Aircraft Spruce call it a - Thermos Style Pressure Fuel Cap
Manufacturer Shaw Plugs call it a "SnapTite"
Part number 51019-4....2 inch
Strong smell of fuel in cockpit after fueling. Traced out whole fuel system from tank through firewall and vent system. No leaks. Was pretty sure I had not over filled and spilled into the dam around the filler and have it ooze into the cockpit. Smell went away after a little. Hmmm.....
Then I noticed the cap was a little looser when putting in in. Now I am fairly particular about keeping it on the setting and not using the "tighten/loosen" adjustment. But it was loose. Went to dial it tighter. That showed the rubber bung had cracked and failed under the compression plate. That would allow fuel to leak - especially from a full tank.
450 hours in service
Looks Normal
But actually split under the compression plate
Graeme JW Smith
GraemeSmith
Re: Thermos Style Pressure Fuel Cap failure
Postby GordonTurner » Thu Feb 10, 2022 7:59 pm
One word. Peter Anson. Hmmm. Two words.
Anyway, consider ordering his replacement and put this problem behind you forever.
Gordon
Postby builderflyer » Thu Feb 10, 2022 10:56 pm
GordonTurner wrote:One word. Peter Anson. Hmmm. Two words.
Gordon
I second Gordon's remarks. Anson's fuel tank cap is one of the nicest additions I've made to my Sonex. Its well worth the cost.
Art,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,Jabiru 3300 #261
builderflyer
Postby DCASonex » Fri Feb 11, 2022 9:33 am
My original tank cap started getting too hard to properly seal after a couple of years, replaced and got about same life. Made my own cap similar to Peter's about the time he came out with his. Now just replace the O-ring every couple of years. Would also recommend getting Peter's will cost less than repeated purchases of the overgrown wine bottle stoppers.
Return to Safety and Training
