ONEX Tires
ONEX Tires
Postby tljones42 » Mon Dec 30, 2013 2:03 pm
Does anyone know if I can use 5.00 x 5 tires on the ONEX mains and still have the kit wheel pants fit (with hydraulic brakes)? About 40 % of my flying will be off airport grass and I think I would like to have slightly larger tires.
tljones42
Re: ONEX Tires
Postby daleandee » Mon Dec 30, 2013 2:29 pm
tljones42 wrote:Does anyone know if I can use 5.00 x 5 tires on the ONEX mains and still have the kit wheel pants fit (with hydraulic brakes)? About 40 % of my flying will be off airport grass and I think I would like to have slightly larger tires.
Sonex shows the same part number for the main wheel pants on the Sonex and the Onex. Many have put the larger tires on the Sonex with the stock wheel pants although a bit of trimming is needed around the opening. Not sure what changes you'll have to make for the hydraulic brakes. I have the Tracy O'Brien brakes and they didn't interfere at all with the wheel pant mounting.
Hope this helps,
Dale Williams
N319WF @ 6J2
Myunn - "daughter of Cleanex"
120 HP - 3.0 Corvair
Tail Wheel - Center Stick
daleandee
Re: ONEX Tires
Postby tljones42 » Mon Dec 30, 2013 4:46 pm
Dale,
That helps a lot. Thanks.
tljones42
Return to Onex
Users browsing this forum: No registered users and 21 guests
