by pfhoeycfi » Fri Aug 27, 2021 4:22 pm
The B flap drive motor comes with a feedback pot. I found an indicator made by another actuator manufacturer that I've been playing around with. It seems to work ok on the bench. The indicator has a series of LEDs that light up as the actuator extends. You can choose via a jumper all or one LED. There is a small pot on the indicator to adjust the LED on/off. Its small, the LEDs are not overly bright, it cost $20 plus shipping. I'm still playing with it and have yet to determine if its suitable to use. If anyone else has let me know.
https://www.actuonix.com/Actuator-Posit ... icator.htm
- Attachments
- LED.jpg (175.77 KiB) Viewed 2147 times
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
