I have not been on this page in a while so I’m doing my best to catch up!
Kai,
I’m just not particularly fond of heel brakes. If I had a choice I’d either have a handle on the stick or toe brakes before I had heel brakes. The coordination between heel brakes and rudder pedals can be tricky and a pain (in my opinion). But like all things, with practice, comes proficiency. You might be able to design a great heel brake mod that works! But I just went with toes. On one of my other planes I made dual handles on the stick and they work awesome.
Zack,
I’m going to try and offer as much information to you as I can, which hopefully other people will learn from as well. As stated previously in the forum I finished my install last year almost 200 hours ago. I destroyed the original Sonex mounts in just hours. I then designed the new bed mount they’re using (the aluminum bracket system) to adapt to the chromoly structure to solve issues at that time. The problem I experienced am experiencing now is a motor mount flex or sag if you will in the chromoly structure. Really the proper mount to have is a ring mount. It would allow for better room for components, it would be lighter, and discourage certain characteristics of a bed mount. Plus a ring mount would allow for turbo charged models, like the 915, which requires the exhaust/turbo system to remain standardized so it would not work with the current bed mount.
With all that being said, my left side parallel bar that the aluminum mount bars attach to (your left side when sitting in the plane), has slightly sagged due to a lack of support. Only about a 1/16” but that translates to a bit at the propeller flange. In talking with Mark, I’m going to do a field upgrade to my motor mount to remove the sag, increase support strength, and hopefully solve the issue. Being that my plane is the only one flying with this mount system and the steady accumulation of hours, it has kind of been turned into a test monkey fortunately/unfortunately. So I will be doing some further modification and I will let everyone know how it goes. With your current set up, your propeller flange WILL NOT, and I’m not saying this to be a Debby downer, stay centered in your cowl and you will end up with an off center spinner. (Low and left if sitting in the plane) and it will look more pronounced with your set up. Your cowl setup is gorgeous. I just don’t want to see it potentially be damaged or have problems. My original cowl for my plane was made with the intention of seeing what worked and what doesn’t, and I’m now in the process of refining the cowling.
I work on Rotax’s everyday and have many hours behind and in front of them. My friend who overhauled my engine before I put it in is a performance Rotax builder, iRmt instructor, mans the Rotax booth at Airventure and one the go to (if not the go to) guys in the U.S.
We’ve talked a lot about Rotax “do’s and don’t s.” The 912uls/ul (carbureted) lends itself well to dual exhaust set ups, or 4 into 1 set ups. As long as you have proper tuning (as you’ve stated) you’ll be fine. You just don’t want any pulses canceling or a surplus of back pressure to keep the engine from breathing properly. After all, an engine is an air pump. It only pulls in as much air as it can push out, it is an exchange for energy. You ideally want a pulse to be accompanied by the next pulse at the proper rate to help cycle air through the engine properly.
However, on the 912is you absolutely have to use their stock exhaust (muffler). Being that it’s computer controlled the exhaust plays a big roll in its operating parameters (o2). So in modification to the exhaust system, it must be “tricked” into thinking its stock but just simply tuning it to stock parameters. Which you are attempting to do so kudos. The problem with your current setup is that the way to do that is to fit a muffler under the mounting truss but now you have radiators in the way. (Which I do also, my radiators are in the exact spot yours are). So that’s a factor to account for. I know at Sonex they’re mounting their radiators to the side allowing for the side ducts on the cowling to provide cooling, then using the under space for the exhaust. Your current exhaust work is a thing of beauty. The only thing I worry about is on hard starts or killing the engine, a Rotax bucks a bit because of its high compression and usually a large propeller up front. So I worry about your exhaust slapping the support it’s directed around. I’m not saying it will, but it’s possible.
Again, I offer my experience just as that. I have no intention of belittling anyones project. Yours definitely is being built with some care. Keep it up!
13brv3,
I’m eager to see you fly that thing! Looks awesome! You may want to dial your pitch in a little more. At WOT at straight and level flight you want to be as close to 5,600 rpm as you can. With your current pitch setting you’ll blow passed that, likely passed the max recommended. Static of 5,300 will get you right where you want to be and give you some more top end.
Someone also asked about the Rotax exhaust growl. My plane I intentionally made it LOUD. I wanted a hot rod and one that sounded like it. I get complements all the time on it’s noise. But in the cockpit it’s no louder than a 3300 or VW. But, you can sure make a 912 whisper which is wonderful in a completely separate way.
I’ll copy the link to an old video but at 11:38 in the video I do a low pass during testing and it gives a good indication of what it sounds like.
https://youtu.be/5lCcuGX2KLcI’m going to try to keep up to date on my current cowling crusade. I’m switching from the dreaded vertical split cowl to horizontal split with a new look and new exhaust and radiator placement. As well as some aerodynamic devices to be added to the plane to clean it up a bit.
I’m so excited for all these builds! They’re all looking awesome. I can’t wait to sit back and see what comes out. I’ll be flying my plane to Airventure again next year, maybe we’ll get one or two more Rotax powered Sonex’s to show up
