Carlos Trigo wrote:Xenos 59 wrote:Regenerative braking is a feature of essentially all electric vehicles where you are able to capture the energy from the wheels (or prop) and push it back into the battery. Google will probably explain it better...
Thank you Gabe
So it’s not possible for the prop to stop completely, and use for example a foldable prop?
There are definitely foldable prop options. Carat and Stemme have two interesting ones. They add complexity and cost, and it seems like a mechanical brake would be easier to implement (most helicopters have such brakes.)
However, the regenerative capability is one of the coolest parts of an electronic aircraft. If you can find lift that will impart energy to your aircraft, you can thermal or cruise in it and instead of using it to gain altitude or speed, use it to recharge your batteries in flight. In theory, you could significantly extend your flight time and land with the equivalent of a full tank of gas. Greg Cole has some YouTube videos and documents on his website discussing this. It's something I hope to explore when I build an electric Xenos myself.
