Skippydiesel wrote:My new Sonex is fitted with the Dynon SkyView system.
It has the capacity to give an angle of attack report, if fitted with the Dynon pitot head.
The angle of attack data can be set to give a pre stall warning potentially a good substitute for a conventional stall warning system
Anyone had any experience with the Dynon Pitot Head, its claim for angle of attack sensing and its potential to provide a pre stall warning //
builderflyer wrote:[quote
It's not necessary to use the "Dynon Pitot Head" to obtain AOA sensing on the Skyview. You can easily make your own system using a downward angling tube or even a rivet placed at the proper location on the wing skin. If you're interested in the tube idea, I can send you a photo showing what works well on my Sonex. If you are interested in the rivet idea, take a look at what Jeff Shultz has done. You'll want to use the audible warning, not the depiction of AOA on the Dynon screen. Once having this system up and calibrated, you'll never want to fly without it.
Art,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,Jabiru 3300 #261
Users browsing this forum: No registered users and 23 guests
