by Bryan Cotton » Thu Dec 09, 2021 10:05 am
I spray either WD40 or silicone onto a paper towel, and wipe the pin off. Besides lubrication, that cleans off the pin. Even if it doesn't seem dirty, there is wear going on and small particles being generated.
Never use a hammer. For the stubborn ones, I hold the bent end with pliers, and rotate it back and forth a little as I push it in. Much easier to break the static friction this way.
For the long cowl pin, I did take a spare pin and flatten/grind the end a little, to make a "reamer." I chucked that up in a drill and did a few passes. I wouldn't do that with ruddervators.
